Activity › Forums › Adobe After Effects › Renders come out with a black background after keying with Keylight
  • Renders come out with a black background after keying with Keylight
    Posted by Christopher Williams on October 9, 2009 at 5:30 pm
    I have Adobe After Effects CS4 and i have been keying some HD footage with Key light 1.2. But when i render and drop my clips into Final Cut 7, it comes in with a black background. In Final Cut I have a white layer under my footage, which should show through my key, when I render out of after effects, I key check it in after effects and it works and I render it, with None compression – RGB + Alpha – Millions of Colors + with Audio. Anyone know why that black background is happening, and way i can fix it? Thanks!
    Joshua Burke replied 16 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Andy George
    October 9, 2009 at 6:31 pm
    Christopher,
    Sounds like your rendering it correctly.
    Sometimes FCP misinterprets your footage with Alpha Channels. In FCP select the
    clip and go to Modify>Alpha type>Straight.
    -Andy
  • Christopher Williams
    October 9, 2009 at 7:11 pm
    I changed to alpha to straight , but the black background is still there, Thanks Tho
    October 9, 2009 at 7:42 pm
    I like to have the flexibility to scale and move my subjects freely from whatever my background is at the time. so if i did it all in AE the background will scale and move with my subjects ect.
  • Gary Hazen
    October 9, 2009 at 8:45 pm
    What does the matte look like in AE prior to rendering? Set the view to alpha only.
    October 9, 2009 at 8:51 pm
    Yeah, my subjects are completely white and everything else is black
  • Kevin Camp
    October 9, 2009 at 10:13 pm
    what happens if you import the keyed footage back into ae. does ae see the key?
    if so, try rendering a mov with another codec. i’d try losseless (rgba, millions+, straight) or png (quicktime png, not png sequence, same settings).
    if neither of those work, i’d give an image sequence a try (tiff or png). apple recently release an update to quicktime, and it’s possible that it broke something… it wouldn’t be the first time.
    one last thing (sorry, but i have to ask)…. you don’t happen to have a black solid in the comp…? if you hit the checker board button in the preview window, you do see checkers rather than black. sorry to ask the obvious, but sometimes it happens 🙂
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Joshua Burke
    November 2, 2009 at 7:20 pm
    Hey
    Hows it going?
    I had the same exact problem you are having. After a lot of messing about I finally fixed the problem. I my render cue in after effects I used the same settings you did and got the same results. My solution came when I went to the arrow next to the output module in the render cue, clicking it brings up a list of presets, I selected Lossless with Alpha. For some reason it worked, I guess that there is some setting in that preset I didn’t have set properly before, I haven’t figured out what yet but right now I don’t care… I can keep working!
