Activity Forums Adobe Premiere Pro Renders cause white flickering Premiere Pro CC2014
  • Renders cause white flickering Premiere Pro CC2014
    Posted by John Alexander on October 21, 2014 at 8:10 pm
    Premiere Pro CC 2014. Pulling my hair out over this: One track and/or effect or multiple tracks and/or effects – i.e. motion resize or reposition, chroma key, multiple layered title page etc. causes white flickering in the video upon rendering. If I go frame by frame the flickers are apparent in the waveform. This was not present in previous versions of software. I recreated a 15 second clip in PP 5.5 and also PP CC which rendered perfectly. I had a chat with Adobe and they had me move some media to C drive and replace shots on timeline which fixed it temporarily but it returned upon restart. Is this common and/or HELP!
    Windows 7 SP1, HP Z210, external 6tb RAID Premiere Pro CC 2014
    Naveen Alle replied 11 years, 8 months ago 3 Members · 3 Replies
  • Grinner Hester
    October 22, 2014 at 6:50 pm
    I ran into this yesterday in CC 2014. It’s the many preview files so if you throw an adjustment layer on top and just render that as one you should be ok (after deleting the old render files)
  • John Alexander
    October 22, 2014 at 6:53 pm
    Grinner,
    Thanks, I’ll try that! I’m still a relative newbie to PP from Avid so I don’t know all of the tricks…
  • Naveen Alle
    December 10, 2014 at 3:22 pm
    Hello,
    Do we need to delete the entire set of preview files often to get rid of this problem? Can you please give a little more insight into the solution?
    I find it very annoying to work with long sequences in the newer version with flickering issues.
    Please help.
