Activity Forums Maxon Cinema 4D Renders are now only B&W?
  • Renders are now only B&W?
    Posted by Bryan Richards on September 27, 2007 at 3:30 pm
    Hi all,
    My renders only output as Black and White, why?
    The greyscale option is turned off in the component menu in the picture /render window. This is set to RGB. Its baffling as to why it started and i simply cannot find an option to revert things back to colour.
    It happened when changing my render settings output from animation to jpeg and the render As editor setting was changed back from software shading to off.
    your help will be appreciated
    kind regards
    Bryan Richards
    Bryan Richards replied 18 years, 10 months ago 2 Members · 3 Replies
  • Bryan Richards
    September 28, 2007 at 7:42 am
    sorted now
  • Brian Jones
    September 28, 2007 at 4:59 pm
    what was the solution (what was the cause? Maybe it would be good to B&W someday)…
  • Bryan Richards
    October 9, 2007 at 10:19 am
    It was a mixture of light settings and material colours that created a black and white illusion.
