Activity Forums Adobe After Effects Renders are failing, need help
  • Renders are failing, need help
    Posted by John Carrington on June 11, 2008 at 8:54 pm
    So my renders are not finishing, they stop at random times, anywhere between 1m 38s in, to 3m 50s in. After they fail whenever I try to do anything it says “After Effects is out of memory” I have a project due tomorrow and i really need help.
    I am working on an 8-core MacPro 16gigs of RAM, working with DV/DVCPro footage at 29.97fps……Quicktime 7.4.1 and i have meesed with my memory and cache settings
    Let me know if you need anymore info, and i thank you very much for the help
    Chris Wright replied 18 years, 3 months ago 4 Members · 5 Replies
  • Todd Morgan
    June 11, 2008 at 9:15 pm
    what are you outputting to?
    Todd Morgan
    Creative Director
    morgancreative
    http://www.morgancreative.ca
  • Kevin Camp
    June 11, 2008 at 9:25 pm
    you may need to use the secret preference (hold the shift key while selecting after effects>preferences>[any pref], then click the preference pulldown to select ‘secret’) to set force ae to purge ram at set intervals. set the ‘purge’ to happen prior to when you see the crash… so if your render crashes at frame 60, set the purge to happen at around 40-50 frames…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • John Carrington
    June 11, 2008 at 9:52 pm
    I am outputting to DV/DVCPro, best quality 4:3
    I will try the secret settings, Thanks for helping guys, hopefully it works.
    Keep the suggestions coming
  • John Carrington
    June 11, 2008 at 10:46 pm
    yeah I have been a lurker for a long while and i used those posts as references.
    So Magic happened and everything is rendering fine now, I did not change anything or do anything different, I just hope this problem doesn’t happen again
    Thank you all for the help and advise, hopefully i can return the favor in the future.
  • Chris Wright
    June 11, 2008 at 11:18 pm
    Your memory is making you crash because AE is locking up.
    Reset your Preferences->Memory and Cache
    Maximum Memory Usage at 120%
    Maximum RAM cache size 60%
    Disable disk cache
