Activity Forums Maxon Cinema 4D Renders are cut off
  • Renders are cut off
    Posted by Kelly Johnson on November 5, 2006 at 2:59 am
    Is there some sort of “Safe Margin” view in C4D 8.5? When I select an output size, the image sometimes adjusts to ‘get into proportion,” but though hitting the preview button shows all, in the small picture window and the actual file saved, the file is getting cut off.
    How Can I tell in my regular view if an image will be cut off without having to render the image first to find out?
    I’ve tried all the Frame Scene and such but the image is still being cut off.
    Shadow replied 19 years, 10 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    November 5, 2006 at 3:18 am
    Yes, you can display the render area (and safe area) guides in the viewport. Check in the viewport configuration menu.
  • Kelly Johnson
    November 5, 2006 at 3:24 am
    Thank you. I had that checked but with a light-gray line, didn’t even know that was onscreen!
    You sure have helped me in the past, thanks.
    kj
  • Shadow
    November 6, 2006 at 8:59 pm
    you can change colors in prefs too.
