Renderman z-depth files in Final Cut Pro for compositing?
Hi there, I’m trying to blend some 2D animation with 3D environments. I am rendering the 3D environments in 3delight (renderman based renderer) and I am able to output a z-depth file. However, I can’t find any information about using z-depth files in Final Cut Pro.
I have read that applications like Shake and Adobe After Effects are more suited to this task since they are designed as effects packages and I now get the impression FCP is intended more as an editing suite but I was wondering if it was possible to do. There are effects plug-ins for FCP and I’d like to be able to apply them using depth files.
I’d quite like to do post-pro z-depth blurring and fog effects.
Z-files are usually just grayscale tiffs that tell you how far objects are from the camera. So to test if FCP has z-depth support, you don’t need 3delight, you can just make an image in Photoshop or something with black on the left of the image and white on the right then try to place layers/effects according to the tiff file. If someone could figure it out and explain how to do it, I’d very much appreciate it.
