Activity › Forums › Sony Cameras › rendering XDCAM HD using PC
  • rendering XDCAM HD using PC
    Posted by Grzegorz Kwiatkowski on September 13, 2012 at 4:14 pm
    I have to render a 30 second commercial for TV station. They accept only certain
    codec type. I am using PC and Sony Vegas. The specs are below:
    XDCAM HD „.mov” with audio
    · codec: MPEG2 (50Mb/s), 4:2:2
    · 25 fps
    · 1920(H) x 1080(V) pixeli
    · interlace. (PAL HD 1080i).
    · audio: 48 kHz,
    · audio: 16 bit.
    Where do I find XDCAM codec? Is it possible to render
    this codec with PC?
    thanks
    Grzegorz Kwiatkowski replied 14 years ago 2 Members · 2 Replies
  • Don Greening
    September 14, 2012 at 8:41 am
    You can only export using the XDCAM HD codec if you have access to it within the Sony Vegas export settings options. Otherwise you’ll need to find another person who can transcode the file for you after you’ve exported from Vegas using a codec that it DOES have.
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Grzegorz Kwiatkowski
    September 14, 2012 at 10:44 am
    This is rather obvious. But is there any transcoding software for PC that can convert into XDCAM HD?
    M
