Activity › Forums › Adobe After Effects › Rendering with transparent background
  • Rendering with transparent background
    Posted by Sarah Morton on January 22, 2010 at 12:54 am
    I’ve created titles in AE CS4, and I can’t figure out how to render the comp without the black background. I need the background to be transparent, or rather, no background at all. In the past I’ve been able to change the Alpha or Item Properties in FCP, but I can’t seem to make it work correctly now. Answers are very much appreciated!
    Sarah
    Vincent Strader replied 16 years, 8 months ago 3 Members · 3 Replies
  • Todd Kopriva
    January 22, 2010 at 2:27 am
    Render and export using a codec that can encode an alpha channel. In the Output Module Settings dialog box, make sure that Channels is set to RGB+Alpha. (When you see Millions Of Colors+ in the format options for some codecs, the plus sign indicates that an alpha channel is included.)
    See this section about output module settings and this section about alpha channels.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Sarah Morton
    January 22, 2010 at 3:15 am
    Thanks so much! It worked perfectly!
  • Vincent Strader
    January 28, 2010 at 12:05 am
    I tired that and got 900 images. WOW! Had to delete them all. I need a self contained movie with a transparent background. Gonna have to try the other option 🙂
