Activity Forums VEGAS Pro Rendering with or without GPU -> Strange pixel effect
  • Rendering with or without GPU -> Strange pixel effect
    Posted by Lucas Pelus on January 25, 2016 at 8:28 pm
    Hello,
    I have a strange pixel effect on a render :
    I got rush from a gopro hero3+ silver -> 1080p50
    The project is 1080p50, the render is 720p25
    If I render with CPU and GPU (CUDA) there is some strange picel in the sky. Check at 00:11 – 00:14 (top right). password is test
    https://vimeo.com/150973510
    When I render with CPU only, everything is normal
    https://vimeo.com/152924365
    I remember on another computer with a ATI GPU, rendering with the GPU was better than without.
    I similar problem than here but in the other way…
    Cannnot understand why.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    John Rofrano replied 10 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    January 25, 2016 at 9:16 pm
    Rendering glitches with GPU turned on happens sometimes. It could be a particular GPU driver version. Sometimes updating your drivers or actually downgrading them will produce different results. CPU rendering is usually consistent and without errors.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
