Activity Forums VEGAS Pro Rendering with GPU slower than my processor rendering?
  • Rendering with GPU slower than my processor rendering?
    Posted by Don Cobble on September 29, 2011 at 3:19 pm
    I was testing rendering speed and found that when I used boris FX which (i think defaults to) GPU for rendering my rendering time almost doubled. I have the Quadro 4000. although it freed my processor by about 80%, which would be good IF i was wanting to run another project on Vegas.
    when rendering with all things being the same on my project _Except adding (Light wrap) my render time doubled and processor use dropped substantially, I might be wrong in my conclusion I think it is the light wrap sending rendering to GPU?
    I want to know is it possible, to control whether I render by GPU or the CPU?
    Thank U
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Vegas Pro 9 32bit & Vegas Pro 9 64bit & Vegas 10 32bit & Vegas 10 64Bit
    Camera
    Sony EX1 shoot in 1920×1080 30P
    Don Cobble replied 14 years, 11 months ago 2 Members · 2 Replies
  • Frederic Baumann
    September 29, 2011 at 9:14 pm
    I have no clue about Boris FX GPU usage, however a thing you could do to investigate is running a GPU monitor such as evga-precision (as illustrated here: https://www.fbmn-software.com/en/gpu.html): the load % will show you if the GPU is used or not.
    Also, you might want to check that you have the right GPU driver. For instance my GPU-accelerated plug-ins require CUDA 4 to be installed, so you have to install a nVidia driver version recent enough to support CUDA 4 (270.61 or above for GeForce cards), otherwise the GPU will just not be recognized. Not sure at all this also applies to Boris FX, but you might want to check.
    Finally, it might happen that your GPU is slower than your CPU, or that memory transfers between mother board and graphics card are too slow, so that in the end, the overall computing time is longer than keeping everything on the CPU. However, with a Quadro 4000, this would be surprising. A good way to check this is using the GPU monitor: if your GPU is almost 100% loaded, then it does all what it can, but cannot go faster than your CPU (which patiently waits for results, having time for other Vegas sessions should you have any…)
    Hope this helps,
    Frédéric
    Want to Match Colors between clips? new plug-in here.
    Check GPU-powered FBmn Software plug-ins to fix White Balance and Exposure issues.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
    Or about Keyframes? Watch this one. French version here.
  • Don Cobble
    September 30, 2011 at 2:20 am
    Frederic,
    I downloaded the monitoring EVGA MY GPU is 0 % usage????? and my CPU is only useing about 20%?? it was 100%. HELP!!!!!
    please
    PC
    I7 2.8 Ghz 8GB Ram
    Win 7 Pro 64bit OS
    PNY Quadro 4000
    3-4 TB HD
    Camera
