Activity Forums Maxon Cinema 4D Rendering with Dynamics tags
  • Rendering with Dynamics tags
    Posted by Andrew Loughnane on February 13, 2020 at 3:02 pm
    Hi all,
    long time lurker, first time poster here. Have started branching into 3d stuff and am having an issue with rendering when I have simulation tags on. My project is a simple fork (rigid body) falling down into frame onto a floor (collider body). Everything works perfectly in the viewing window in the program but as soon as i go to render it is entirely out of frame and the render viewer doesnt even seem to correlate to the same animation. Ive spent hours online looking it up and have found mnultiple people with the same problem but none of their solutions worked for me.
    I have baked the animation into the cache and my export frame rate matches my project frame rate. Even when I use the interactive render region I can see in real time how theyre framed and animated completely differently. Any ideas?
    Andy
    Veronica Barron replied 6 years, 6 months ago 3 Members · 2 Replies
  • John Williams
    February 18, 2020 at 10:56 am
    If you’re happy to send the C4D scene file I can take a look;)
    John Williams
    Soho Editors
  • Veronica Barron
    February 24, 2020 at 3:02 pm
    I’m not sure what’s your problem but perhaps the frame rate in the project’s settings panel and the frame rate in the render settings panel is not the same, there are not according.
