Activity Forums Adobe After Effects Rendering w/ MB Misfire Crashing
  • Rendering w/ MB Misfire Crashing
    Posted by Kurt Zaiser on December 2, 2011 at 12:36 am
    If I had hair, I’d be pulling it out. Hoping some of you folks can shine a light.
    Bottom line is that I cannot render anything if I use Misfire’s Dust or Splotches sub-effects. AE renders a few dozen frames and fails. If I don’t have either of those two options checked in the effects window, I can select all the other Misfire sub-effects (but Post Contrast) and the renders run fine. When it crashes, Task Manager doesn’t yield much (to me). CPU % hovers around 50%-85% depending upon how many sub-effects I’ve checked and RAM usage ranges from 12GB to 16GB. The log file always says “There is an error in background rendering so switching to foreground rendering…”. It said this when I had only 8GB in the PC and repeats now with 20GB installed.
    The project is taking a 3 layered PSD file, a 60 second 720p MXF from an EX1 that’s being keylight’d and compositing/rendering them all to 720×480 std-def WMV or MOV.
    My i7 PC has 20GB DDR3 and is running Vista Ultimate. I seldom have render problems unless I do some effects-heavy comps. Also seemingly irrelevant is enabling/disabling multiprocessing. When on, I have it set to 2 CPU’s reserved, 3GB per CPU and it says 4 CPU’s will be used. 4GB is reserved for other apps. I have fiddled with RAM and CPU balances to no avail.
    Anybody have any thoughts or suggestions?
    Phillip Berg replied 10 years, 8 months ago 6 Members · 8 Replies
  • 8 Replies
  • Kurt Zaiser
    December 2, 2011 at 6:07 pm
    Thanks Dave.
    Sorry I didn’t mention the version (it’s listed in my profile). I’m using CS5x64. I am using MB suite but it’s 1.4 – maybe that’s the trouble. Perhaps I should trial the latest version. Should have thought of that before posting. I’ll also try a lossless version of the input video and see if that helps – thanks for the idea.
    Regarding OpenGL, I have read plenty of posts from Todd so I always have OpenGL off.
  • Kurt Zaiser
    December 2, 2011 at 6:48 pm
    Just tried rendering an uncompressed AVI with only Misfire applied. Checked the heavy/noisy sub-effects and get the same result – render fails after a few seconds.
    Also dusted off CS3 – MisFire renders fine with seeing only 4GB of RAM. So, seems like MB 1.4 and CS5 don’t play nice together. Must be an x64 vs x86 thing. Not surprising, I suppose, given the time between their release dates.
    I guess I’ll have to try the latest MB trial version and see if that helps. I stopped updating after AE 10.0.1 because everything was just the way I wanted it (until I tried using MisFire recently).
    Back to the trenches…
  • Kurt Zaiser
    December 2, 2011 at 9:26 pm
    Sigh.
    Got the latest MBSuite trial (version 11) and same thing happens – as soon as I check “Dust” or “Splotches”, individually or in combination with other MisFire sub-effects, the render fails after a few dozen frames.
    Even updated to the current ATI drivers a few weeks ago when I upgraded to Vista Ultimate to use all 20GB.
    Oh, well. 11 out of 13 ain’t bad. If anyone has any ideas (maybe it’s my graphics card?), please let me know.
    Thanks.
  • Alejandro Fridman
    January 23, 2012 at 2:31 pm
    Hi Kurt, if you have activated the “dust” option in the MisFire settings, remove it and try to render again. If this solve your problem you can use the dust effect with another plugin like MB Looks.
    cheers!
    https://www.rendervous.tv
  • Chris Axum
    February 28, 2012 at 2:00 pm
    I have the same issue (cs5.5 64 quad win 7) misfire crashes on dust and splotches. I too have tried different settings, blah blah blah. It is misfire and those two effects.
  • Agustin Garcia bollini
    September 29, 2013 at 3:49 pm
    Hello, to skip this issue fast and homemade style, I brought the linked comp from AE CS6 into Premiere CS6, then I exported that piece and it WORKED!!
    FYI:
    I have applied MisFire Splotches, MisFire Dust and MisFire Flicker at the same time + Indie Look.
    With an HP Envy dv4
    Hope this helps..
  • Micz Kicz
    September 6, 2014 at 3:42 pm
    I have similar problem. Don’t know for sure by which parameter of Misfire it’s caused by, but I’m sure it’s Misfire’s fault.
    I have tried importing this comp to Premiere, but I get “Unknown Error” while rendering from PR.
    My situation is bizzare, because I have pretty strong hardware (i7 3770 + 32 GB RAM + RAID-0) and the comp is very modest (720p, one layer png sequence with only Misfire applied). Only the lenght could affect the renders badly – the comp is 11400 frames long.
    I render to PNG sequence, but from time to time I get an error (25 :: 241). It occurs randomly, after 1 to 500-600th frame. And recently – even the notifications stopped and render …just fail on a random frames. Always those are different frames, and when I try to pick up render after the fail – the problematic frame isn’t an issue anymore. Or sometimes it still fail on the same frame, and then I have to Purge Memory (“Ctrl” + “Alt” + “/” on keypad) and hit render once again – it usually renders the problematic frame then.
    Does anybody already know what could be the cause of that?
    Creative Creature 🙂
  • Phillip Berg
    January 21, 2016 at 3:44 pm
    I found a work around to this problem.
    You simply add your dust and splotches to an adjustment layer and then that adjustment layer only last for 5 seconds. You can then copy paste it all the way until the end of your project.
