Activity Forums Adobe After Effects Rendering Video with transparent Background
  • Rendering Video with transparent Background
    Posted by Kurt Ehlmann on August 30, 2011 at 3:35 pm
    Is it possible to Render an after effects video with a transparent background. An example being if I wanted to drop a lower third as a title over the a video on a differnt editing system than adobe. If so, how?
    Aj Riding replied 11 years, 5 months ago 6 Members · 7 Replies
  • 7 Replies
  • Josh Pappas
    August 30, 2011 at 4:36 pm
    Yes it is! For starters, make sure your comp actually has a transparent background, not simply a black background, by toggling “Toggle Transparency Grid” button at the bottom of the comp viewer (it’s the small, checkered button). If the background changes to the checkered pattern, you’re good to go.
    The only other thing to deal with is the proper output settings. Not all codecs support an alpha channel. I typically use these settings in the Output Module:
    Format: Quicktime
    Format Options
    -Video Codec: Animation
    -Quality: 85 to 100, depending on how critical quality is. 100 is uncompressed.
    Channels: RGB + Alpha
    Depth: Millions of Colors+ (the “+” indicates the alpha channel)
    Color: Straight (Unmatted) – This avoids a luminance shift in semi-transparent areas that you get with “Premultiplied (Matted)”
    Others use TIFF or PNG image sequences instead of Quicktime Animation, but the underlying concept is the same.
    Hope this helps!
    Josh
  • Kurt Ehlmann
    August 30, 2011 at 6:22 pm
    Fantastic! Thankyou
  • Josh Pappas
    August 30, 2011 at 7:39 pm
    You’re quite welcome! You might also be interested in downloading the free Knoll Unmult effect, which is perfect for creating transparency on items where you would normally use “screen” or “lighten” blending modes to see the underlying layers (such as a lens flare applied to a black solid). It creates an alpha channel based on the luminance of the layer, which is very handy.
    Enjoy!
  • Falafel Raptor
    August 21, 2012 at 7:35 am
    thanks for this!life is now easier.
  • Anthony Mcleod
    January 3, 2013 at 2:56 pm
    This has helped me so much. Thank you!
  • Muhammad hafiizh Alias
    October 14, 2014 at 4:50 am
    thanks so much dude!!
  • Aj Riding
    April 12, 2015 at 6:39 am
    Thanks, that a huge help!
