Activity › Forums › VEGAS Pro › rendering two programs at once
  • rendering two programs at once
    Posted by Roger Bansemer on January 17, 2011 at 8:08 pm
    If I open two instances of Vegas and render two different files at one time, will that most likely cause problems and errors. I’m guessing it will but wanted another opinion before I spend hours rendering only to find out. Thanks
    Jeff Schroeder replied 15 years, 8 months ago 3 Members · 2 Replies
  • Tom Pauncz
    January 17, 2011 at 9:32 pm
    Roger,
    With a huge proviso that if you have enough resources, you should be OK.
    I have done this many times with simple renders. The more complex your video – FX, mixed media, etc. the more resources you’ll need.
    Cheers for now,
    Tom Pauncz
    (30WEST MEDiA GROUP)
  • Jeff Schroeder
    January 18, 2011 at 12:44 am
    I have done this for smaller work without trouble. If you are rendering large projects, (I’ll let you define “large”), you might want to stack them with a script so they render one after the other.
    Jeff
    http://www.narrowroadmedia.com
