Activity Forums Adobe After Effects Rendering two passes of Xvid codec in After effects.
  • Rendering two passes of Xvid codec in After effects.
    Posted by Motenai on March 21, 2006 at 10:22 pm
    Hello to everyone. First of all, i must say sorry for my poor english and i wish i can explain my problem so clearly as i can.
    Usually i render my videos in uncompressed rgb and after that i encode it in Xvid using VirtualDub because in that program i can use the two passes of the Xvid encoder, thing that i don’t know how to do in after effects. Anybody knows how to enqueue two passes-encoding in after effects? I tried almost everything and searched almost all the web and i can’t find anything about it. Thanks.
    Mylenium replied 20 years, 6 months ago 3 Members · 2 Replies
  • Joe Bird
    March 22, 2006 at 4:56 am
    If I understand the question, perhaps look up “add render module” which will allow you to render ar different output settings at the same time.
  • Mylenium
    March 22, 2006 at 6:47 am
    You can’t do that in After Effects. AE has no way to store temporary analysis info somewhere and acces multiple rendered frames for compression this way (that’s why it usually the worst option for any compressed CoDecs). If you needed such functionality, you would have to have a dedicated export module such as the MPEG-II and Windows Media plugins. So to make things short: stick with exporting uncompressed and then using VirtualDub.
    Mylenium
    [Pour Myl
