Activity › Forums › Maxon Cinema 4D › rendering to wireframe
Posted by Manny Rellesiva on February 14, 2007 at 12:52 pmIm new to cinmea 4D. I would like to render my scene as wireframe…is that possible? How? thanks in advance.
Adam Trachtenberg replied 19 years, 7 months ago 4 Members · 4 Replies -
Ingemar Björling
February 14, 2007 at 2:08 pmRender > Render Settings > Render as Editor
Or, get the wireshader plugin here: http://www.c4dportal.com (dont know if it works in R10 though)/Ingemar
Renderwise Ingemar Bj
Adam Trachtenberg
February 14, 2007 at 2:11 pmIt’s possible. You have to enable the “cel renderer” post effect in render settings and check the edges box. It’s pretty basic. If you have Sketch & Toon it offers a tremendous amount of flexibility in terms of line style, hidden lines, etc.
Mylenium
February 14, 2007 at 6:31 pmto provide one more alternative: Get DiTools and use Tessa to generate geometry based wireframes. This is the most reliable method as it works with all rendering techniques for Shadows, Reflections etc.. The only limitation is that it can be slow on large objects. You can get something similar by selecting all polygons on an object and using Intrude or Bevel, then deleting the unwanted faces.
Mylenium
[Pour Myl
Adam Trachtenberg
February 14, 2007 at 7:25 pmYou can also use the Atom Deformer if you want to go the geometry route.
