Activity Forums Sony Cameras Rendering to same aspect as preview
  • Rendering to same aspect as preview
    Posted by Curt Gustafsson on March 2, 2010 at 3:42 am
    I have HDV footage and Vegas Pro 9c. Vegas properties are set to 1920×1080. Render settings are set to HDV 720×480.
    In the Vegas Preview window all is normal, but when rendered the height measurement is shrunk so that the top of video and immages are cut off.
    How can I render HD footage so that the rendered results corresponds to what I see in Preview?
    Also, after installing 9c (a couple of times) Help files (as well as context helps) are not available. How can this be fixed.
    I have used Vegas Video since v. 5.0
    cgustaf
    Niall Harkin replied 16 years, 6 months ago 2 Members · 1 Reply
  • Niall Harkin
    March 2, 2010 at 6:24 pm
    Not used Vegas in an age, but if you want to export the same as the Vegas properties “1920×1080” which would be your preview, just select it in your export size, or do a custom export.
    But the best thing to do would be to change your timeline / vegas settings to match that of your source footage and export ratio, check your cut and output at the native size.
    What is the output for?
