Activity Forums Adobe After Effects Rendering to Quicktime
  • Rendering to Quicktime
    Posted by Yoondo on June 1, 2005 at 12:47 am
    Situation: rendering out to Quicktime with the layers at best quality
    comp window is at half resolution
    output module at current settings
    output size 720×389(scale down v. of 2K 1.85×1 ratio)
    Question for Mr.Steve Roberts.
    Because of the fire effects that I used, the rendering time is a bit long; just wanted a quick render to preview it.
    So, I rendered it out as current setting as mentioned above, it renders out to half the size(360×195) or so.
    I haven’t streched the size in the output settings.
    is there a reason for this reduced in size?
    Thanks in advance.
    Yoondo replied 21 years, 3 months ago 2 Members · 4 Replies
  • Steve Roberts
    June 1, 2005 at 3:25 am
    The comp rendered out to half resolution, since the comp window was currently set to half Res. (current settings were half-res)
    Steve
  • Yoondo
    June 1, 2005 at 4:26 am
    Hi Steve,
    Thanks for the reply.
    To do a quick render to QT, should I then set the comp to full resolution
    and make the layers draft? I still need to get the size but a quicker render
    would be nice rather than best and full settings.
    I normally render everything out to best & full, that’s why I’ve never came
    across this issue.
    Thank you for your help.
  • Steve Roberts
    June 1, 2005 at 11:14 am
    Try using the render queue at quarter-res Render Settings, then stretch to full size in the output module. You don’t have to create a full-length render to test a solution.
    Experiment. That’s how I learned the app back in ’97.
    Steve
  • Yoondo
    June 2, 2005 at 12:15 am
    I will do as you suggested.
    Thank you, Steve.
