Activity › Forums › Adobe After Effects › Rendering to Quicktime with alpha
  • Rendering to Quicktime with alpha
    Posted by Matthew Beall on October 19, 2009 at 8:18 pm
    I’m trying to render to a DNxHD Quicktime with alpha.. I have the settings properly set up in the render queue, but I never get an alpha channel.. If I render the same output to an image sequence, it works fine..
    -Matthew
    Todd Kopriva replied 16 years, 11 months ago 2 Members · 2 Replies
  • Matthew Beall
    October 19, 2009 at 9:29 pm
    Looks like a DNxHD problem.. All the other codecs work fine..
    -Matthew
  • Todd Kopriva
    October 20, 2009 at 12:38 am
    DNxHD somewhat recently added alpha channel support (or at least this is what I read a year or so ago). Maybe you don’t have a recent enough version of the codec.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
