Activity Forums Adobe After Effects rendering to quicktime problem!
  • rendering to quicktime problem!
    Posted by Alister on May 28, 2006 at 4:26 am
    something is terribly wrong-In AE i’ve been rendering animated compostitions into basic quicktime clips and everything has been fine, but everytime i render this one composition and play its quicktime version, it freezes and does not play smoothly. It is a simple set of jpgs animated as moving across the screen.
    Does anyone know what could be wrong??
    Alistair Liddell replied 20 years, 3 months ago 3 Members · 3 Replies
  • Enzo Tedeschi
    May 28, 2006 at 11:15 pm
    What codec have you rendered your animation to? If you have rendered the QT as a ‘None’ compressor (uncompressed video), and your drives are not fast enough, that my account for the bad playback.
    I have seen exactly what you are describing when attempting playback of a uncompressed file from a 7200rpm drive.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Alister
    May 29, 2006 at 11:57 pm
    Hi, Im not sure how to change the compressor when rendering to QT… which menu do i look in? I’ve just been using the presettings. So if i can compress my renderings, i may have better playback?
    thank you so much for all the help you’ve been giving me, everything has been working out so far!
  • Alistair Liddell
    May 30, 2006 at 5:06 pm
    apple_m for make move
    click on where it sayes Lossless in your output Module
    click on Format options
    under Compression type select something like photo jpeg and change your quality to High
    you will then be able to play back your animation without it stutering.
    Alternatively if you have got Quicktime Pro export it as another option
