Activity Forums VEGAS Pro Rendering to master issue
  • Rendering to master issue
    Posted by Eric Adler on February 1, 2019 at 3:53 pm
    So I normally import raw MTS files recorded off my canon g20 camcorder, I then edit the project and the save the master as a M2T file using
    MAIN CONCEPT MPEG-2 HDV 1080-60i template
    that gives me the highest quality master possible which is what I’m looking for before I then encode to mp4.
    Today after the render I am getting square pixels running diagonally down the screen from left to right, this is happening throughout the video, these artifacts are not present in the raw video.
    Using a laptop to do the rendering with a dedicated video card, no issues until today. Have rebooted etc..
    George Dean replied 7 years, 7 months ago 3 Members · 3 Replies
  • Francois Pénzes
    February 2, 2019 at 1:40 am
    Hi Eric
    Just a shot in the dark here but, could it be a bad cable? Something hardware related ? I did muck around with some files back when and I found, in that instance, that it was a bad cable.
    Unfortunately we tend to skip over the obvious culprit(s)…..
    The more you become knowledgeable, the more you tend to disregard the basic stuff and go for the complicated solution.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Eric Adler
    February 7, 2019 at 4:25 pm
    So I seem to have this issue with more than one video but not the majority of them, since the raw files appear to be ok when viewed it doesn’t appear to be a cabling issue
  • George Dean
    February 7, 2019 at 7:46 pm
    eric,
    Have you tried GPU acceleration ‘On/Off’?
    Did Windows update your GPU drivers? If so, fall back to the previous.
    Have you performed a full reset to your Vegas Pro?
    Best Regards……George
