Activity Forums VEGAS Pro rendering to different frame rate
  • rendering to different frame rate
    Posted by Wouter Wynen on February 18, 2009 at 12:41 pm
    I have an entire project setup for 25fps. Now I need to render a file to 24fps, but I don’t want vegas to drop frames to get to 24fps. I would rather like vegas to just process each frame and just make a 24fps video, so that in fact it will play just a bit slower.
    Is this possible? What I’m doing now is render to 25fps avi, take that in virtualdub, change fps to 24 and render again to avi… That just changes the frame rate and slows the file down a bit. But it’s too much work and my final file needs to be wmv which virtualdub doesn’t support, so doing the same straight out of vegas would be much easier.
    wouter
    John Adler replied 17 years, 7 months ago 3 Members · 4 Replies
  • Steve Rhoden
    February 18, 2009 at 9:52 pm
    Have you already rendered your project using the 24p
    template and noticed a problem ?…………Because you should
    not have a problem there.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Portfolio at:
    http://www.youtube.com/hentys
  • Wouter Wynen
    February 18, 2009 at 10:06 pm
    No not yet, I was just wondering. The same for example if I would want to render it at 50fps without vegas adding frames and keeping it the same duration, but just render it with 50fps and doubling the speed by doing that.
    Not that it will look bad or anything, but I guess that when rendering a 25fps project to 24fps, vegas will probably drop every 25th frame no?
    thanks for any info!
  • Wouter Wynen
    February 19, 2009 at 5:03 pm
    Here’s what happens when rendering to 24fps….
    That’s what I want to avoid ofcourse 🙂
  • John Adler
    February 25, 2009 at 12:59 am
    I’m new here myself, but I think this will work:
    Select all the events, right-click, and under “Switches” select “Disable Resample.”
    -John
