Activity Forums Adobe Premiere Pro Rendering to Bluray in Media Encoder
  • Rendering to Bluray in Media Encoder
    Posted by Philip Merten on September 12, 2008 at 12:51 pm
    Greetings:
    I just did my first rendering to Bluray using the Media Encoder and found it amazingly slow compared to what it takes for a SD DVD to render. I used the Bluray H264, CBR, 20. It took about 15-20 minutes to render a two minute clip. Is this normal? Also, what is the highest recomended setting when space is not an issue?
    Thank you very much…
    Philip
    Philip Merten replied 17 years, 11 months ago 2 Members · 2 Replies
  • Jeff Pulera
    September 12, 2008 at 2:02 pm
    Hi Philip,
    Encoding H.264 takes about 5x longer than encoding MPEG-2 for Blu-ray, and if using 2-Pass then double that again!
    At low data rate settings, H.264 will provide a better quality than MPEG-2, BUT – at higher quality settings that advantage is mostly lost as MPEG-2 can provide a beautiful image at high data rates.
    As long as you have room on the disc, you can crank up the data rate and just use MPEG-2 for Blu-ray and you’ll find it looks quite nice. Try a setting of CBR in the 25-30 range. Of course, if you can let the system run overnight then H.264 is an option.
    Jeff Pulera
    Safe Harbor Computers
    http://www.sharbor.com
  • Philip Merten
    September 12, 2008 at 2:13 pm
    Thanks Jeff, I’ll give it a shot!
