Activity › Forums › Adobe After Effects › Rendering to Big Screens with unusual Aspect Ratio
  • Rendering to Big Screens with unusual Aspect Ratio
    Posted by Sebastian Rivera on March 22, 2013 at 8:50 pm
    HI, Everyone. I think this is my first post in CreativeCow, but have been a big fan since forever.
    My question is as follows- I have an L.E.D Screen 20mm dot pitch – that is 4 wide by 60 feet height.
    I want to render my footage from AE and Premiere and make it fit perfectly like a glove.
    How do I convert the 4 x 60 aspect ratio to something I can Put in after effects or premiere?
    Also
    I am wondering if this is the right workflow?
    I render out 1080 width and 1920 height then re import it to a composition that is the aspect ratio conversion of 4 x 60 and scale the imported footage to fit the new comp
    what do you thinK?
    is there a way to specify the dot pitch amount so that AE and Premiere knows?
    I’ll appreciate your help greatly!
    Walter Soyka replied 13 years, 6 months ago 3 Members · 4 Replies
  • Darby Edelen
    March 22, 2013 at 9:58 pm
    You should never need to know dot pitch when working in AE or Premiere. The only things that matter when creating content with AE for a specific display is that display’s pixel resolution and pixel aspect ratio.
    You can simply match your composition settings to these values and you should be good to go.
    Darby Edelen
  • Sebastian Rivera
    March 22, 2013 at 10:17 pm
    Thank you Dave and Darby.
    Darby
    is there a math formula to get the aspect ratio based on the screen dimensions and maybe the dot pitch?
    or do you get the aspect ratio based on the resolution?
    I can ask the screen manufacturers about the resolution but I am not sure they will give me the aspect ratio.
    Dave
    I will try to contact Walter Soyka if by the end of the day I am still a bit confused.
    thanks for the tip.
  • Darby Edelen
    March 22, 2013 at 10:35 pm
    If you have the pixel resolution of the display and the physical aspect ratio you can determine the pixel aspect ratio with some simple arithmetic.
    Pixel Aspect Ratio = (Physical Width / Physical Height) / (Pixel Width / Pixel Height)
    In all likelihood (and in my experience) an LED array will use a square pixel aspect ratio.
    Darby Edelen
  • Walter Soyka
    March 25, 2013 at 7:13 pm
    [Sebastian Rivera] “My question is as follows- I have an L.E.D Screen 20mm dot pitch – that is 4 wide by 60 feet height. I want to render my footage from AE and Premiere and make it fit perfectly like a glove.”
    You should ask for more information on the playback system and pixel mapping for this LED display.
    My back-of-the-napkin calculations suggest that the native resolution of this display is somewhere in the neighborhood of 61 x 915 pixels. However, depending on the video processing necessary to feed that LED system, that may be immaterial.
    You need to get a delivery spec that you can work with, so you can be confident your content will play as intended.
    Walter Soyka
