Activity Forums Adobe After Effects rendering to an m2v
  • rendering to an m2v
    Posted by Dan Schaffner on March 24, 2008 at 2:32 pm
    Is rendering an m2v out of AE comparable to using Compressor? Will the quality be about the same? I just noticed the option to change the render settings to Mpeg DVD in the new AE CS3 and was wondering if this was a good way to create m2v files.
    Thanks.
    Joseph Springer replied 18 years, 5 months ago 3 Members · 3 Replies
  • Dan Schaffner
    March 24, 2008 at 3:18 pm
    Would using AE be better than using an older version of QuickTime to make the m2v?
  • Darby Edelen
    March 24, 2008 at 4:43 pm
    [Dave LaRonde] “Why use a generic “make an m2v file” setting when in Compressor you select a preset that would get you better quality for the file’s length?”
    I will add that AE’s MPEG-2 encoder is pretty top-notch (it uses the Main Concept encoder). However, it is still valuable to have Lossless files if you need to go to other formats.
    In my own personal workflow I almost exclusively render to MPEG-2 out of AE because I render almost exclusively for DVD menus. It saves time, disk space and confusion to render directly to MPEG-2 in my case. When I need to render for broadcast, however, I will render Lossless and transcode from there to whatever is needed.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Joseph Springer
    March 24, 2008 at 5:13 pm
    Rendering the lossless copy from AE and then using one of the dedicated compressors — Compressor, Squeeze, & Cleaner– is definitely a useful and efficient workflow for most situations, Mr. Rabinowitz speaks to this here:
    https://cowcast.creativecow.net/podcast/an-introduction-to-video-compression–12
    Regards,
    Joe Springer
    Certified Adobe After Effects Training and Premiere Training Instructor
