Activity Forums VEGAS Pro rendering to a specific file size
  • rendering to a specific file size
    Posted by Brent Holland on July 12, 2013 at 6:51 pm
    I have rendered a project to hi rez and the file size is 3.5 gigs. I need to make it much smaller around 10mps. Is there anyway to set this up in 12 Pro?
    Brent Holland replied 13 years, 1 month ago 2 Members · 2 Replies
  • Aleksey Tarasov
    July 13, 2013 at 4:37 pm
    Bitrate (bits per second) defines the output size, so you need to set the desired bitrate in the selected render template.
    [Size in bytes] = [Bits per second]/8 * [Duration n seconds]
    video plugins
  • Brent Holland
    July 13, 2013 at 7:57 pm
    thank you my friend much appreciated
    Folks at Vegas naychance you could implement an easy to use algorithm in the next release I am sure I am not alone in the desire for a tool to dictate file size. Thx all
    https://www.nightfrightshow.com
    https://www.brenthollandshow.com
