Activity Forums Adobe After Effects Rendering to 720p 24…
  • Rendering to 720p 24…
    Posted by Craig Thomas on April 27, 2005 at 11:46 pm
    I am doing a project with After Effects, Final Cut Pro HD and DVCPro HD using 720p 24 footage.
    When creating animation (pure graphics with no footage) in AE, does anyone know what the settings to render back to FCP so it conforms to 720p 24????
    Steve Freebairn replied 21 years, 4 months ago 3 Members · 2 Replies
  • Phiphat
    April 28, 2005 at 7:35 am
    you can do an NTSC D1 720 by 486, and on the frame rate part just type in 23.97
    p
  • Steve Freebairn
    April 28, 2005 at 10:01 pm
    If you are doing HD which it sounds like you are then your resolution should be 1280×720 and the frame rate should be 23.97. If you export at 720×480 then that is EDTV not HD.
