Activity Forums VEGAS Pro Rendering to 1920×803 – missing audio
  • Rendering to 1920×803 – missing audio
    Posted by Will Brown on January 31, 2011 at 2:18 am
    Hi guys,
    I would like to render 1920×803.
    If I use MPEG2 – HDV1080 and change the 1080 to 803, I have audio, but it has black lines (from the 1440 that is not 1920).
    If I change the 1440 to 1920, it can’t render, so I presume I have to use a Blu-ray template.
    When I use MPEG2 – Blu-ray 1920×1080 and change the 1080 to 803 and include audio, I have 2 files, the main .m2t and an extra ‘movie clip’ that is the audio?
    Why is the audio going to a separate track?
    Is that how Blu-ray works?
    Thanks.
    Will.
    John Rofrano replied 15 years, 7 months ago 2 Members · 4 Replies
  • John Rofrano
    January 31, 2011 at 4:50 am
    1920 x 803 is not an accepted Blu-ray format. You must render letterboxed as 1920 x 1080 using one of the Blu-ray templates. Then render your audio separately as Digital Dolby AC3.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Will Brown
    February 1, 2011 at 2:37 am
    Hi John,
    Thanks, I got you.
    Can I render Blu Ray with 1 file.(audio into the video)
    Thanks.
    Will.
    PS.They should pay you the amount of responses you give.
  • Will Brown
    February 1, 2011 at 3:01 am
    No worries John,
    I will render as mp4, HDV 1920×1050, 16Mbps.
    Thanks.
  • John Rofrano
    February 1, 2011 at 12:13 pm
    [Will Brown] “Can I render Blu Ray with 1 file.(audio into the video)”
    You can but if you want to burn it to disc, the audio will get re-rendered and you will loose quality. It’s best to deliver the video and audio as separate streams to avoid any re-rendering. If you just want to use the file for playback like on a media player, you can combine them.
    ~jr
