Activity Forums VEGAS Pro Rendering time stopped but not because of hang
  • Rendering time stopped but not because of hang
    Posted by Emmanuel Virgil Albelda on October 24, 2020 at 5:09 am
    Hi can anyone help me? Im rendering a 10 minute film with lots of color grading and sound design, its understandble that it took 12 hours upon renderinh however whenever the render percentage reaches 43 percent it suddenlt stopped and never moved for no reason im using hp latop core i5 10th gen, I know some of you might think it hang but it never did, i can sill click the software its just that the rendering process stopped hueheueheu im crying right now the deadline is today and it is a big project help ?
    Graham Bernard replied 5 years, 10 months ago 2 Members · 1 Reply
  • Graham Bernard
    October 24, 2020 at 7:05 am
    Lessons to learn: With Mission Critical work do segmented Renders.
    1) You at least get progressive finished work.
    2) Any issues will so up.
    3) NLE Render work is THE most intensive work your PC will ever do.
    4) ADD render times/issues to your project planning. I do. I don’t expect to be able to Create and then go forward to render. You’ve already said it’s a complex FX-rich project.
    5) Be aware of the restrictions of your PC. Are you running VP18 on an i5? I’ve got SSDs and an i9 MONSTA, and I’m aware of the need to not allow my creativity to over-step my Setup. If I do, and why not, ?, then I employ “conservative” progressive workflow-renders.
    Do you require any further suggestions?
