Activity Forums Adobe After Effects Expressions Rendering time increased by 6 times when expression layer is switched on
  • Rendering time increased by 6 times when expression layer is switched on
    Posted by Raj Sha on July 29, 2019 at 9:23 pm
    Hello Again,
    I am coming from this thread:
    https://forums.creativecow.net/thread/227/42339
    Here Andrei helped me in making an expression to change the color of the text inside parenthesis in a text box.
    However, when I render my project in AME, it takes around 18-20 minutes to render in H.264 1080. When I switch off this layer, it hardly takes 2-3 minutes to render entire composition. Can anyone suggest if this is normal, or is there anyway code can be optimized?
    Thank You!
    var t = text.sourceText;
    var splitText = t.split("\r");
    var regex = /\(([^)]+)(?=\))/g;
    function indexMatched(index){
    var matched = false;
    var match;
    while ((match = regex.exec(t)) !== null){
    matched |= match.index<index & indexmaxIndex){
    maxIndex += splitText[i].length;
    i+=1;
    return i-2;
    indexMatched(textIndex+placeInLines(textIndex)) ? 100 : 0;
    David Cabestany replied 7 years, 1 month ago 4 Members · 4 Replies
