Rendering Templates
Posted by William Van on June 7, 2011 at 9:36 pmI want to render at 1400x1080p with a bitrate of 13mps.
There is no template in Vegas 10 with any of these settings.
How do I make a custom rendering template?
William Van replied 15 years, 3 months ago 2 Members · 7 Replies -
John Rofrano
June 8, 2011 at 1:12 am[William Van] “How do I make a custom rendering template?”
Select a template that is close, then press the Custom… button in the Render As window. Change the bit rate to anything you want (within the limits of the codec).
~jr
http://www.johnrofrano.com
http://www.vasst.com -
William Van
June 8, 2011 at 8:13 pmI’ve already tried that.
There are no templates with 1440x1080p.
And no templates with 1300 mps.
John Rofrano
June 9, 2011 at 1:41 am[William Van] “There are no templates with 1440x1080p.
And no templates with 1300 mps.”I’m sorry if I’m not being clear. Start with an HDV 1440×1080-60i template and press the Custom button. Then change the field order to “None (Progressive Scan)” and Bit-rate to 13,000,000.
~jr
William Van
June 9, 2011 at 5:56 amWhen I choose the AVCHD 1440×1080 60i template, the field order slot is not highlighted so I can’t change it. The only way I can render it is as 1920×1080 30p. I want to render it it as 1440X1080 30p
Also, I can’t choose 13,000,000 because the only choices are 192,000 384,000 768,000 4,000,000 10,000,000 15,000,000 26,000,000.
William Van
John Rofrano
June 10, 2011 at 2:54 pm[William Van] “When I choose the AVCHD 1440×1080 60i template, the field order slot is not highlighted so I can’t change it. The only way I can render it is as 1920×1080 30p. I want to render it it as 1440X1080 30p “
So don’t select AVCHD. Use the Internet 1920×1080-30p template and change the Frame size to High definition (1440×1080).
[William Van] “Also, I can’t choose 13,000,000 because the only choices are 192,000 384,000 768,000 4,000,000 10,000,000 15,000,000 26,000,000.”
It’s an editable field. Type in any number you want (like 13,000,000).
~jr
William Van
June 13, 2011 at 9:50 pmOK, I edited the bit rate to 13,000,000 but when I change the Frame size to High definition (1440×1080) the rendered file has black bars on each side.
The 1440×1080 raw footage from my camera fits the whole screen in 16×9 ratio.
