Activity › Forums › Apple Motion › rendering straight unmatted
  • rendering straight unmatted
    Posted by Raybies on June 28, 2007 at 8:01 pm
    does anyone know where the ‘straight unmatted’ render setting is in motion? i’m trying to render out a quicktime animation for use in an avid but they’re coming out premultiplied resulting in a ‘dark halo effect’ when keyed over footage.
    in the past the fix with live type was to take the quicktime and re-render it from after effects as straight unmatted. is there an easier way? thanks in advance.
    Martin Baker replied 19 years, 2 months ago 2 Members · 3 Replies
  • Martin Baker
    June 29, 2007 at 3:42 pm
    It’s in the Output tab of the Export Options window. Uncheck “Use current project and canvas settings” and “Premultiply alpha” and you’ll get a straight render.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
  • Raybies
    June 29, 2007 at 5:57 pm
    i unchecked the box and exported a new quicktime as straight unmatted. for some strange reason the quicktime still imported into the avid with the same ‘dark halo effect’ when keyed over footage. the import settings in avid are what they should be.
    am i missing something?
  • Martin Baker
    June 30, 2007 at 11:18 am
    Whatabout in QuickTime Player – Does it look like it’s been rendered straight (bad quality edges)?
    Martin
    Avid2FCP
