Activity › Forums › Adobe After Effects › Rendering stops
Rendering stops
Posted by Jerker on January 18, 2006 at 10:31 amEvery time I have movie longer then 23 sec, the rendering process stop at 23 sec. Is there preference I’ve missed here? Can anyone tell?
Enzo Tedeschi replied 20 years, 8 months ago 3 Members · 8 Replies -
Tim Kurkoski
January 18, 2006 at 6:42 pmAre you getting an error message, or what exactly happens? When you say rendering, are you rendering a RAM preview or out to a file? If to a file, what format and settings are you using?
Enzo Tedeschi
January 18, 2006 at 8:38 pmThis may be jumping the gun, but check that you are rendering “Entire Comp” in your render settings, and not “Work Area Only”. It sound like you may have a work area set to 23 secs in the comp. Alternatively, you can adjust the work area to be longer if indeed this is the issue.
Enzo Tedeschi
____________________________
Editor
Sydney, Australia -
Jerker
January 18, 2006 at 9:35 pmHaving set the Work Area to a smaller time range is a classical misstake, but havn’t done that. And I get no error messages. AE just stop and in Windows XP i can find tha AE doesn’t answer. It totaly shuts down. And I have also tried to use another computer with two diffrent AE projects och compositions. Either there is a preference in AE or there is a preference in Windows XP that I don’t know of.
Jerker
January 18, 2006 at 9:43 pmI use:
Format: No Compression
Channels: RGB + Alfa
Depth: Millions of Colors+
Color: Premultiplied (Matted) -
Jerker
January 18, 2006 at 9:54 pmI also tried another formats, but the same thing happens again. It just shut’s down.
Tim Kurkoski
January 18, 2006 at 11:20 pmHave you tried using a different format, or different settings? Have you tried rendering a different comp?
Enzo Tedeschi
January 19, 2006 at 12:57 amHave you also tried the usuals… trashing prefs etc?
Maybe an AE reinstall… :o(
