Activity › Forums › Maxon Cinema 4D › Rendering stills
  • Rendering stills
    Posted by Andy Beck on November 24, 2009 at 9:20 am
    I’ve heard its for animations to render them as stills and then use other software to create your animation? Does anyone do this and could you advise on which software would be best?
    Andy Beck replied 16 years, 10 months ago 4 Members · 6 Replies
  • Randy Johnson
    November 24, 2009 at 10:36 am
    Yes, its best to render them as image sequences (stills). You can play and convert image sequences in most software including quicktime, Avid, After effects, Final Cut pro, Motion, Shake, Combustion …
    For quick test renders there is no reason not to render quicktime or AVI but for the full res longer renders I would stick to image sequences.
    /Randy
  • Dominik Gut
    November 24, 2009 at 1:08 pm
    Hey Andy
    I agree with randy johnson, because (to me) there are two main reason to render image sequences and not movies:
    1) you could already see mistakes in the first frames of the animation
    2) if your computer crashes, only the frame he was working on is lost, and not the whole movie, you have been probably rendering since 2 days…
    so mostly to check only the animation, I render a so called editor-rendering, where no lights or textures are rendered. You just see what you already see in the editor, but in realtime! Huge advantage!
    Still I render only image sequences. I never do movie renderings. But I guess that could be part of your own personal “taste” of workflow.
    kind regards, Dominik.
    http://www.phirstfilm.com
    Phirstfilm Productions GmbH
    film and animation for business solutions
    Zurich, Switzerland
  • Andy Beck
    November 24, 2009 at 1:39 pm
    Thank you both for your input I think I’ll definately render as an image sequence from now on (still quite new to this).
    Andy
  • Andy Beck
    November 24, 2009 at 2:45 pm
    Ok, I may just be missing something simple but I cant get Quicktime to play a tiff sequence that i rendered?
    How do I do it?
    Thank you in advance
    “NEVER MIND I NEED QUICKTIME PRO AND I ONLY GOT THE BASIC VERSION”
  • Adam Trachtenberg
    November 24, 2009 at 3:50 pm
    If you have R11.5 you can compile still frames into a movie file directly within Cinema’s picture viewer — no external application needed.
  • Andy Beck
    November 24, 2009 at 3:52 pm
    Time for an upgrade then!
