Activity Forums VEGAS Pro Rendering Speed w/Vegas
  • Rendering Speed w/Vegas
    Posted by Geoff Chandler on March 2, 2010 at 5:37 pm
    I do DVD production on-location at stage events and redering speed is very important to my work flow. I understand the faster the processor, the faster my rendering, but what I don’t know is if my “quad-core” is automaticlly being utilized or does the program (Vegas in this case) has to be written to maximize quad-core or 64 bit processors. I’m going to make a new computer dedicated for these jobs and want to make sure I’m not wasiting money if Vegas doesn’t even use the extra “cores.” I assume moving up to 64 bit will speed up rendering since Vegas has a 65 bit version? Thanks, Geoff
    Chris Giddens replied 16 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Martin Phillips
    March 2, 2010 at 9:40 pm
    Hi geoff,
    I’ve just moved to Vegas 64 bit and I must say the render times are roughly one third of what they use to be. Now faster than real time and that’s with 2 pass setting. My new system is i7 12 gb ram, and Vegas has defaulted to 16 cores. Martin
  • John Rofrano
    March 2, 2010 at 11:16 pm
    As Martin said, the Intel Core i7 with 12GB of memory is a good platform to use and Vegas will take advantage of all the cores. I would definitely use Windows 7 64-bit as your OS. If you want maximum rendering power, get a two CPU motherboard with Quad Xeon processors and 16GB of RAM. This will give you 8 cores and Vegas will use them all.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Geoff Chandler
    March 3, 2010 at 12:04 am
    Thanks. This is exactly what I needed to know.
  • Chris Giddens
    March 3, 2010 at 1:49 am
    Hello
    This is my first post here – I’m hoping you can help.
    We have an i7 based machine with Windows 7 Ultimate 64 bit and 12Gb of Ram.
    We are currently running Vegas Platinum v9 (not Pro) and DVD Architect 4.5.
    Performance for rendering etc doesn’t seem to be any different from when it was running on a 32 bit system.
    My suspicion is that Vegas Platinum and DVD Architect 4.5 are only 32 bit applications – is that right?
    When you guys refer to 64 bit Vegas – is that Vegas Pro and DVD Architect 5?
    I’m hoping you can help me unleash the potential of the hardware and operating system we have!!
    Chris
  • Martin Phillips
    March 3, 2010 at 6:21 am
    My understanding (having looked through the Sony creative site) is that your software doesn’t come in 64bit. (you might want to check this out tiyself with Sony). If that is the case, then that is your problem. It’s doesn’t matter who much ram your system has, my understanding is that you will only be able to use about 4 gb instead of the 12. Hope that helps. Maerin
  • Martin Phillips
    March 3, 2010 at 6:30 am
    Forgot to say. Vegas pro 9 comes in both 32 & 64 bit versions. Dvda 5 has just the one version ( I think ). Martin
  • Chris Giddens
    March 3, 2010 at 6:41 am
    Hi Martin
    Sounds like Vegas Pro is what I need – time to get the credit card out and visit the Sony Creative website!!
    Thanks again for your time and knowledge – much appreciated!
    Cheers
    Chris
  • Martin Phillips
    March 3, 2010 at 10:42 am
    Just a little tip – check on the price of an upgrade from the software you have, and/or getting an older version of Vegas pro and upgrading that !!!
  • Geoff Chandler
    March 3, 2010 at 1:37 pm
    Also, if you happen to be a student (or have a student in your house) or a teacher, you can purchase most software at a discount at JourneyEd.com
  • Chris Giddens
    March 3, 2010 at 11:02 pm
    Thanks Geoff and Martin – appreciate your advice.
