rendering speed problem.
I have a serious problem with a certain scene.
Right now, I am working on five different scenes of the same kind.
one has a serious rendering speed problem.all the other scenes render within a couple minutes – 15 minutes max. but this one takes about 60 minutes.
This one took 6 Minutes
GI creation was disabled for all textures except for the wall and ground materials, for the red “hotel” sign and unfortunatelyfor the glass. But I have to add, that I turned it off just for testing, and the result was pretty much the same.
GI Portal is enabled for the Glass,
GI mode is IC
GI depth is set to 2
(sorry, german Version here, i hope this is the right expression)If anybody has any hints, what the problem might be, shoot!
I’m out of ideas.PS: an early rendering test of the first scene at final resolution 31,4 cm X 29,7 cm at 300dpi took almost 40 hours!
