Activity Forums Adobe After Effects Rendering Specs: URGENT
  • Franky Torres
    September 28, 2007 at 5:25 am
    also, should I interlace or just render off the fly?
  • Steve Roberts
    September 28, 2007 at 3:27 pm
    If your comp contains no imported footage, you can choose to render interlaced or not. It is your (aesthetic) choice, unless the producer specifically asked for nterlaced.
    If you do render interlaced, make sure you choose the right field order for whatever hardware is spitting your project out to tape.
