Activity Forums VEGAS Pro Rendering Specs in Vegas
  • Rendering Specs in Vegas
    Posted by Steve Rogers on February 1, 2011 at 7:02 pm
    Trying to send my video edit off and the place im trying to send it to gave me these specs but im not sure what settings in Vegas to use
    STANDARD DEFINITION:
    • AVI, MOV or MXF Container
    • 720×486 or 720×480 for NTSC and 720×576 for PAL
    • 29.97 or 23.976 (23.98) frame rate for NTSC and 25 for PAL
    • Video Codec/Format (in order of preference):
    o Uncompressed 8-bit 4:2:2 in UYVY/2vuy or YUY2 byte order
    o HuffYUV lossless 4:2:2 in AVI container or Bitjazz Sheer lossless Y’CbCr
    8bv in MOV container
    o Apple ProRes 422 (HQ)
    o Sony MPEG-IMX/D10
    o DVCPRO50
    • Uncompressed PCM audio, 48KHz or 44.1KHz sample rate, 16/20/24-bit depth,
    Little Endian or Big Endian byte order
    Thanks for your help
    John Rofrano replied 15 years, 6 months ago 3 Members · 3 Replies
  • Edan Cohen
    February 1, 2011 at 9:08 pm
    Steve —
    Under the “file” menu you’ll see an option entitled “render as”. Click on that and you’ll be offered a menu of output options which correspond to the specs you listed.
    For example, you can choose AVI, then manually set the AVI export options according to their preferred specs.
    Make sense?
    Dell Studio XPS Core i7 // 860 @ 2.80GHz
    Windows Home Premium x64
    8GB RAM
    ATI Radeon HD 5700
  • Steve Rogers
    February 1, 2011 at 10:39 pm
    what if i dont see anything that looks like those specs..what would be the equivalent
  • John Rofrano
    February 2, 2011 at 2:07 am
    Since they will accept HuffYUV, I would download the HuffYUV codec (it’s free) and install it. Then start Vegas, load your project, go to File | Render As… and select Video for Windows (*.avi) and start with the “Default Template (uncompressed)“. Press the Custom… button and for the Video Format select HuffYUV. Then save the template under a new name and use that to render.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
