Activity › Forums › VEGAS Pro › rendering slows down as it goes, processor not used
  • rendering slows down as it goes, processor not used
    Posted by Jaanus Henno on January 19, 2014 at 2:04 pm
    Hi!
    I have a weird issue going on. Made a project, set on render, starts off nice, but then as it goes it gets slower and slower. Process manager shows that while in the beginning the cpu was used around 80%, now it’s like between 30-50%. Why is that happening? The render is still going on, now around 75% completed.
    Actually I already detected this happening before, but it did appear lately. I use a laptop for the work. Put the same project on to a desktop and it goes fine. So it should be conneted with laptops hardware. GPU on both computers is not used for rendering. There’s plenty of hard drive space and source material is on an external drive.
    As for project settings, I’m upgrading an old VHS captured avi file to HD, using BCC UpRez, levels, color correction, sharpening, Neat etc., and lots of keyframing.
    Cheers.
    Nigel O’neill replied 12 years, 8 months ago 5 Members · 6 Replies
  • Graham Bernard
    January 19, 2014 at 4:10 pm
    Everything about your Project shouts massive render time. Sorry.
    Grazie
  • Steve Rhoden
    January 19, 2014 at 11:19 pm
    Render intensive project you have there, So all that
    sounds normal to me.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Jaanus Henno
    January 20, 2014 at 1:59 am
    Yes, that is true what you are saying, but the question remains: Why does the project/Vegas start to use less resources of cpu as the render goes? Why it’s not stable?
    I did finish the rendering though and it came out as supposed to, but I would like it to be stable, even if slow. At least I know then how much render time it takes, right now it’s increasing and increasing. That is not good, I have to plan my works and this thing is unpredictable.
  • Stephen Mann
    January 20, 2014 at 3:58 am
    I use a laptop
    Rendering is processor intensive, and as you heat up the processor, the laptop will throttle the clock slower to cool it off. Depending on the processor, it may park some cores.
    Try running the free program – coretemp – to monitor your CPU temperature and determine if the slowdown correlates to the heat buildup.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Jaanus Henno
    January 20, 2014 at 5:16 am
    I see. That makes sense. I will try to test it with a cooling pad, though I doubt it will help a lot. But if it does, I will start carrying it around.
  • Nigel O’neill
    January 21, 2014 at 3:10 am
    Depending on how much Neat Video you are applying, it can slow things down. Vegas on my system does not hog all of the CPU, so what you are seeing is probably a bit of CPU throttling by the OS to keep things running cool, plus Windows leaving something in reserve. I have only seen my CPU hit close to 100% when I have been running 3 renders simultaneously
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
