Activity Forums Maxon Cinema 4D Rendering Size Question
  • Rendering Size Question
    Posted by Troyan Turner on August 26, 2009 at 3:25 pm
    First off, I’m sure this has been discussed ad nauseum on these forums and I apologize as I wasn’t even sure what to search for. I have an animation I’m finishing and the largest size it will be presented will be a 42″ plasma. I’m running short on time to get it rendered and was wondering what the smallest size is I can render this animation and still look good on a 42″ plasma? In the past I’ve rendered at 1920 x 1080 but I’d like to get away with a smaller size if possible. Thanks in advance!
    3D is my life. Cinema 4D is my blood.
    Troyan Turner replied 17 years, 1 month ago 2 Members · 2 Replies
  • Tim Shetz
    August 26, 2009 at 4:12 pm
    Hi Troyan –
    I usually use the NTSC D1 Widescreen Sqare Pixel preset. It’s under the Film/Video section in the presets in the render settings Output tab. Should be 864 x 486.
    Of course Adobe has decided that that aspect is now different. Something like 872 x 486.
    In Cinema use the preset…it should make it big enough to look good, but small enough to be manageable.
    Hope that helps.
    Tim
  • Troyan Turner
    August 26, 2009 at 4:19 pm
    Thanks a ton, Tim! I really appreciate it!
    T
