Activity Forums VEGAS Pro rendering settings for windows media video
  • rendering settings for windows media video
    Posted by Moira Elefson on July 4, 2024 at 4:47 pm
    hi,
    i am a regular visitor to your wonderful forum for a long time
    many of my questions i have regarding video edit have been answered through your forum although please let me ask something about windows media video rendering
    i have to edit and render some candid videos and i wish to know if my rendering settings are ok
    the only reason that i prefer to render those videos to windows media video is because is take a short time for the rendering to be finished and the final rendered video is under 150 mb in size
    unfortunately, i am working with an old dekstop pc (fujitsu core 2 duo cpu intel e7200 with a limited ram of 6 gb ddr2 800)
    My main pc a four core amd cpu have been broken so i have to build soon a new one but for the time being i have to finish my renderings on that old fujitsu pc…
    here is my rendering settings
    720p x 1280, cbr 6 mbps for video, audio @ 192 kbps @ 48 khz cbr for audio, video rendering quality use project settings (best setting does not give any better quaslity)
    all the videos were recorded by a lumia 650 mobile windows phone
    vegas pro 13
    lumia 650 General
    Complete name : C:\Users\My Pc\Videos\WP_20240617_14_08_23_Pro.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp41/isom)
    File size : 108 MiB
    Duration : 1 min 51 s
    Overall bit rate : 8 134 kb/s
    Frame rate : 29.970 FPS
    Encoded date : 2024-06-17 17:08:25 UTC
    Tagged date : 2024-06-17 17:08:25 UTC
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L3.1
    Format settings : CABAC / 1 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference : 1 frame
    Format settings, GOP : M=1, N=30
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Source duration : 1 min 51 s
    Bit rate : 7 932 kb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 29.970 (29970/1000) FPS
    Minimum frame rate : 7.502 FPS
    Maximum frame rate : 30.426 FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.287
    Stream size : 106 MiB (98%)
    Source stream size : 106 MiB (98%)
    Color range : Full
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.709
    Matrix coefficients : BT.470 System B/G
    mdhd_Duration : 111614
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 1 channel
    Channel layout : M
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 2.59 MiB (2%)
    Source stream size : 2.59 MiB (2%)
    many thanks in advance
    Hector Vera replied 2 years ago 2 Members · 6 Replies
  • Hector Vera
    July 8, 2024 at 3:30 pm
    I used to render everyone of my Sony Vegas videos to WMV format as well for that very reason, it consumes a lot less space on your computer compared to MP4 or MOV from my knowledge. WMV format is what I used on older computers I used to have for editing videos in Sony Vegas back in the day. I used to render these WMV files to 480p instead of 720p back then. And at least your computer has 6GB of RAM, I used to render Vegas videos with even less RAM than that so it should work on your end for 720p. At least its decent for the old computer you have to use for now. What happened to your other computer that broke if I may ask?
  • Moira Elefson
    July 9, 2024 at 8:24 am
    hi hector,
    i thank you so much for your kind reply
    i have tried some different settings for my candid videos and it seems that the follow settings work pretty good on my pc…
    windows media video – video bitrate 12 M cbr (two pass)
    audio @ 192 kbps 48 khz
    project settings – render quality best
    dynamic ram – 25% (i have 6 gb of ram ddr2 800)
    no preview
    i am happy with the results, good video quality and small video size
    my amd athlon a6 3650 was a decent computer but unfortunately the motherboard, an asrock a55 avs was so good
    after two years of use the motherboard couldn’t see the ram
    i kept the cpu and i bought another motherboard so i have to build again my very trusty amd a6 dekstop
    thanks
  • Hector Vera
    July 9, 2024 at 9:01 pm
    Thats good to hear that your settings was good enough for you to be able to do your project. And what do you mean by “No preview”, your preview on Sony Vegas is like showing blank or black screen and cannot see whats going on? If that happening to your current old computer that you are using now or the new one you were building?
  • Moira Elefson
    July 12, 2024 at 7:53 am
    hi hector,
    just to clear it out… preview off is only for the rendering process… since it give me some shorten rendering times
    soon i hope i will build my new pc
    thanks
  • Hector Vera
    July 17, 2024 at 2:22 pm
    Ohh I see so in other words, while you are rendering a video in Vegas Pro, it just does not show the preview so you can see the progress on how its rendering right? Yeah it could be as you say that hardware limitation from the computer you are currently using to render the video. Once you upgrade it, it should be working again.
    If anything else is the issue, try checking this video out to see if it helps: https://www.youtube.com/watch?v=0lrFF6aogeg Good luck and hope it works one way or another.
  • Moira Elefson
    September 4, 2024 at 8:04 am
    hi, many thanks for your kind reply and the video
    apologies for the very long delay in thanking you
  • Hector Vera
    September 4, 2024 at 4:08 pm
    Its okay, always happy to help if needed! 🙂
