Activity Forums Apple Final Cut Pro Legacy Rendering settings
  • Rendering settings
    Posted by Brad Mirman on April 15, 2010 at 11:32 pm
    How can I be sure that I am setup to retain as much image quality when I export from FCP. Right now I am shooting on Canon 7D and using MPEGStreamclip to convert to ProRes LT or ProRes 422.
    I am concerned that after rendering segments time and time again I am losing quality.
    Also what would be that absolute best export settings if I wanted to show something I shot in a theater?
    John Fishback
    replied 16 years, 4 months ago
    2 Members · 1 Reply
  • John Fishback
    April 17, 2010 at 7:46 pm
    When you render inside FCP you lose no quality. When you Export make sure you DO NOT check “Recompress All Frames.” That will result in a quality loss. Just Export Quicktime using “Current Settings.”
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
