Activity › Forums › Apple Final Cut Pro Legacy › Rendering Settings
  • Rendering Settings
    Posted by Steven J. gilbert on February 15, 2011 at 6:36 pm
    I have captured a computer screen tutorial that needs to be transferred to FCP. I have recorded the screen at 800×600 to be close to the 720×480 SD resolution I need. When I render, the screen capture looks horribly blurry. What rendering settings should I use? If my work flow for screen capture needs to change as well please interject. Thanks.
    Zane Barker replied 15 years, 7 months ago 3 Members · 6 Replies
  • Zane Barker
    February 15, 2011 at 6:47 pm
    [Steven J. Gilbert] “When I render, the screen capture looks horribly blurry”
    What are your timeline settings?
    [Steven J. Gilbert] “I have captured a computer screen tutorial that needs to be transferred to FCP”
    What codec is your screen capture in?
    **Hindsight is always 1080p**
  • Richard Cooper
    February 15, 2011 at 6:50 pm
    I think that if you have the option to do your screen capture to 720×480 this would be the best approach. When you put your 600×800 file on the 720×480 time line everything would have to be rendered and most likely down scaled slightly, which Final Cut is notoriously NOT good at.
    Also, once you have the screen capture at 720×480, depending on the file format you are able to capture to, I would trans code this file to ProRes 422 before editing, if it is not already. This will enable you to edit without rendering and will give you a much smoother work flow.
    Hope this helps.
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Steven J. gilbert
    February 15, 2011 at 7:47 pm
    I am using Camtasia Studio 7 for screen capture. My FCP timeline settings I am adjusting. What compression should I try using? Animation, Photo – JPEG?? Thanks.
  • Zane Barker
    February 15, 2011 at 9:22 pm
    [Steven J. Gilbert] “I am using Camtasia Studio 7 for screen capture. My FCP timeline settings I am adjusting. “
    That answers NONE of the questions I asked.
    Look at the list of easy setups in FCP, pick a screen record setting that matches one.
  • Steven J. gilbert
    February 15, 2011 at 10:48 pm
    Are you looking for the codec in Camtasia or FCP? I used an animation codec to render the timeline after import. THanks for your assistance.
  • Zane Barker
    February 15, 2011 at 11:05 pm
    [Steven J. Gilbert] “Are you looking for the codec in Camtasia or FCP?”
    BOTH you should have them match.
    [Steven J. Gilbert] “I used an animation codec to render the timeline after import.”
    Like I said they match, so only use that as your time line settings if thats the codec you screen capture in.
    If posible use the ProRes Codec.
