Activity Forums Apple Final Cut Pro Legacy Rendering screws it up!
  • Rendering screws it up!
    Posted by Brian Pitt on April 24, 2008 at 5:24 pm
    I have some interviews that I shot with a Sony V1U HDV 30p. I imported the footage as prores. Very suprisingly, I was able to pull a decent key in FCP using the Boris Key filter. The key looks great, but once I render, it looks AWEFUL!
    I’m on an uncompressed 8-bit timeline. Does anyone know why rendering makes it look so bad?
    Brian
    Jeremy Garchow replied 18 years, 4 months ago 3 Members · 6 Replies
  • Aaron Neitz
    April 24, 2008 at 5:41 pm
    you need to be working in a ProRes timeline. Timelines should generally match your footage exactly. give that a whirl
  • Brian Pitt
    April 24, 2008 at 6:12 pm
    My mistake…I am working on a prores timeline.
    Brian
  • Jeremy Garchow
    April 24, 2008 at 6:22 pm
    What version of Boris do you have? I have some problems with keying and an upgrade patch solved it.
    Jeremy
  • Jeremy Garchow
    April 24, 2008 at 7:47 pm
    Oh, and another thing, try putting the 422 chroma smoother on (I know it doesn’t make sense) but that worked as well.
    Jeremy
  • Brian Pitt
    April 24, 2008 at 8:30 pm
    I’m pretty sure I have version 5, but I’m not positive.
    How do I put on the 422 chroma smoother?
    Brian
  • Jeremy Garchow
    April 24, 2008 at 8:38 pm
    It’s a separate filter located in the effects > Key folder. Put it on top of the BCC keyer in the filter stack. If you have BCC5, make sure to upgrade to 5.0.4 or whatever that latest patch is.
    Jeremy
