Activity Forums Adobe Premiere Pro Rendering R3D files to Prores Proxies using Media Encoder?
  • Rendering R3D files to Prores Proxies using Media Encoder?
    Posted by Dirk Dejonghe on August 18, 2012 at 6:54 pm
    I need some help!
    I need to render proxies from 5K Epic files. I made a watch folder with all presets for Prores Proxy HD. When I copied the R3D files to the watch folder, only the first of the spanned media got converted properly. Files were for example A001R001xxxxxx.001.R3D … 002.R3D….003.R3D etc.
    Usually the 002 and following media were improperly rendered.
    When I dropped the same files directly into Media Encoder, they were properly rendered (except 2) but appeared as single files instead of spanned media; 001,002,003 should all come together is a single Quicktime instead of three, it was one long take.
    What am I doing wrong? Is Media Encoder the right tool to do this?
    I am working on a MacPro 32GB but no Red card installed. I need to give the Quicktimes to outside editor, my Premiere can handle R3D files OK.
    Last question; where do I access the R3D settings (if at all possible in Premiere?)
    Dirk DeJonghe
    Dirk Dejonghe replied 14 years ago 3 Members · 4 Replies
  • Tero Ahlfors
    August 19, 2012 at 9:12 pm
    It only exports the clip as a whole. I have no idea why you would want to split it and I’ve never ever heard that someone would do that nor done it myself. To access R3D settings right click the clip in the project panel and choose source settings.
  • Richard Cooper
    August 20, 2012 at 12:48 am
    I would try RedCineX Pro. you can download it here for free.
    Very powerful and made for this(and MUCH more).
    Good Luck!
    Richard Cooper
    FrostLine Productions, LLC
    Anchorage, Alaska
    http://www.frostlineproductions.com
  • Tero Ahlfors
    August 20, 2012 at 6:52 am
    Redcine X is powerful in the way of options it has. When it comes to transcoding performance Adobe Media Encoder beats it.
  • Dirk Dejonghe
    August 21, 2012 at 11:05 am
    I wanted a foolproof way of making proxies that anyone could do (presets, mouse drag and drop, etc)
