Activity › Forums › DaVinci Resolve › rendering r3d Bit Depth setting
Posted by Mika Joon on November 24, 2010 at 1:39 amhello everyone
for best quality rendering Red material using RedRocket should I be setting Bit Depth settings to 16 from 10 when rendering to DPX or anything in that matter
thanks
Oyvind Stiauren replied 15 years, 9 months ago 6 Members · 8 Replies -
Craig Harris
November 24, 2010 at 3:37 am16 Bit is better than 10 Bit, but the human eye won’t see much of a difference between the two.
You should always export to 16 Bit when your files are going to a VFX house. That is where 16Bit is much better.
Hope that helps.
Oyvind Stiauren
November 24, 2010 at 10:34 pmOn my system (Linux), you get the following options when I select the rendering format:
DPX RGB 8bit
DPX RGBA 8bit
DPX RGB 10bit
DPX RGB 16bitI haven’t tested what DPX formats it actually can read, but I assume that it at least will support the above mentioned formats.
Oyvind Stiauren
Post production supervisor, Colorist
TerminalMexico City
Uli Plank
November 25, 2010 at 6:58 amI noticed that you mentioned a format with RGBA as well. Does this mean that an integrated alpha channel is supported on Linux? I can’t get ProRes 4444 alpha working on the Mac, only external matte files.
Director of the Institute of Media Research (IMF) at Braunschweig University of Arts
Mika Joon
November 25, 2010 at 7:27 pmDoes this 10 – 16 bit setting affect how an uncompressed QuickTime is rendered as.
Oyvind Stiauren
November 25, 2010 at 9:35 pmDoes this mean that an integrated alpha channel is supported on Linux?
I don’t think so. I can read 8, 10, 12 and 16 bit RGBA DPX files, but I haven’t been able to use the alpha as a matte.
Oyvind Stiauren
TerminalMexico City
Oyvind Stiauren
November 25, 2010 at 9:36 pmDoes this 10 – 16 bit setting affect how an uncompressed QuickTime is rendered as.
No, we’re talking about the bit setting for DPX files only.
Oyvind Stiauren
TerminalMexico City
