Activity › Forums › VEGAS Pro › rendering Quicktime in Vegas 12
  • Bernie Lademann
    March 5, 2013 at 9:28 am
    Hi Larry,
    Yes, I set it to 1. (I have an 8 core CPU which should be able to operate on 16 threads at once.) I believe Vegas is not managing the threading correctly and the symptoms crop up in many places, this being the latest.
    Cheers,
    Bernie.
  • Larry Brewer
    March 5, 2013 at 4:24 pm
    And again, no luck with resetting my max number of threads to 1. I will admit that I was surprised to see that the render speed of 1 thread was about the same as the render speed of 4, or even 8 threads. And they all crashed at 25% – 28%. So for me at least, the jury is still out on the cause of this on my end.
  • Jonathan Thomas
    August 24, 2013 at 5:34 pm
    Guys.. make sure you delete the fail MOV files before you re-render. The mov.sfl file that is still on your drive needs to be deleted. I have found that mov.sfl needs to be removed, in order it to render another clean mov clip.
Page 3 of 3
