Activity Forums Apple Final Cut Pro Legacy Rendering question. Lost.
  • Rendering question. Lost.
    Posted by Mike Armstrong on February 18, 2009 at 4:30 pm
    A friend of mine came to me with the problem that every time he imports a clip onto the timeline he has to render it first, before he can view it.
    He’s running Final Cut 5.1. I tried a simple test to see if I could view footage in the timeline without having to render.
    All sequence settings were the same except the compressor setting. I’m using Apple Intermediary codec & he’s using HD1080i60
    Any reason for this? I could not figure it out.
    Mike Armstrong replied 17 years, 7 months ago 2 Members · 2 Replies
  • Shane Ross
    February 18, 2009 at 4:39 pm
    [Mike Armstrong] “Any reason for this?”
    Yes…you said it yourself…
    [Mike Armstrong] “All sequence settings were the same except the compressor setting. I’m using Apple Intermediary codec & he’s using HD1080i60”
    EVERYTHING needs to match…especially the Compressor.
    Shane
  • Mike Armstrong
    February 18, 2009 at 5:49 pm
    Thanks so much Shane!!
    “Rage against the Dying of the Light”
