Activity Forums Apple Final Cut Pro Legacy Rendering Question
  • Rendering Question
    Posted by Max Jackson on August 10, 2011 at 4:41 am
    Hi CC,
    This is my second major project (for me at least) using FCPro (v.7).
    Every time I take a clip insert it, nudge it, etc. it then says ‘unrendered’. I can’t touch any clip in my sequence without it needing rendering. I don’t remember needing to render 40-50 times every time I edit something.
    I’ve got to be doing something wrong. I just transferred the files from Premiere and it doesn’t require this. The last project I edited in FCPro a couple years ago didn’t need require me to wait 5 minutes to render every 2 seconds to see my video either.
    What am I screwing up? Going crazy.
    Chris Tompkins replied 15 years, 1 month ago 4 Members · 4 Replies
  • David Johnson
    August 10, 2011 at 4:45 am
    It sounds like your sequence settings don’t match your footage. Try starting a new sequence with any random preset, then drag your footage into the timeline and, when you get the window that asks if you want to conform the sequence settings to match the footage, click “yes” this time.
  • Max Jackson
    August 10, 2011 at 4:57 am
    Hi David,
    It wouldn’t drag for some reason, so I selected everything, and COPY/PASTED into the new sequence. It didn’t even give me the pop-up window. But now it’s giving me the colored bars up top like I’d expect. Not just a bunch of red/purple.
    Everything just works. (sigh) Thank you. Thanks a bunch. I’ll remember now if my whole comp is behaving super whack, to do the whole bait and switch to see if that works.
    Thanks a bunch.
    Best,
    -m
  • Rafael Amador
    August 10, 2011 at 10:13 am
    Why don’t you just duplicate the sequence?
    [Max Jackson] “It wouldn’t drag for some reason, so I selected everything, and COPY/PASTED into the new sequence. It didn’t even give me the pop-up window”
    Drag first ONE clip to conform the sequence to the sequence.
    Then do whatever you want.
    You can not conform the sequence by “pasting” anything.
    rafael
    http://www.nagavideo.com
  • Chris Tompkins
    August 11, 2011 at 6:43 pm
    Create a NEW sequence.
    Drag a clip from your browser.
    Then you get the box asking, say yes.
    Delete that clip.
    Copy your editing sequence clips with the render issue
    and paste into new sequence.
    Chris Tompkins
    Video Atlanta LLC
