Rendering question
Posted by Jorge Trinchet on November 18, 2008 at 12:00 amHello,
I have a quick question about rendering.
I am currently working on a 20 minute long project. I rendered it the other day (as a NTSC DV Widescreen, by the way), and for some reason it rendered the project as two separate files. One of the files was 18 minutes and 48 seconds long. The other file was just 1 minute and 41 seconds long. The small file had the last scenes of the project and it was given an extension number “01”.Does anybody know why the project was rendered as two different files? This seemed to happen out of the blue.
Thanks a lot!!!
Jorge
Terry Esslinger replied 17 years, 10 months ago 2 Members · 15 Replies -
Terry Esslinger
November 18, 2008 at 5:11 pmIt sounds like your drive is formatted as FAT32. It needs to be reformatted as NTSF. Otherwise there is a 4GB file limit.
Jorge Trinchet
November 18, 2008 at 11:16 pmThanks, Terry!
Could you tell me how I can do that? I am not sure of how to start…
Thanks again,Jorge
Terry Esslinger
November 19, 2008 at 7:17 pmOne way. Double click on My Computer. Riht click on the drive in question. Choose properties. It will show you whether the drive is Fat32 or NTSF. If it is FAT32 you will need to convert it…
Now use the Windows XP convert tool: Go to Start | All Programs | Accessories | Command Prompt (or, from a Run box, type CMD) and, assuming you intend to convert C:, give the command:
VOL C:
Note the name of the disk in the first line, and the Volume Serial Number (for example, 3F4E-2D1B) in the second. Then type:
CONVERT C: /FS:NTFS
It will ask for that name in confirmation. Then it will ask two further questions. Reply Y each time to set up conversion to happen at the next boot, then restart the machine. (If you are converting a partition other than the operating system’s partition, you may find that it runs without rebooting.) After returning to Win XP, the hard disk will work for two or three minutes, tidying up. Leave things alone during this time.
Jorge Trinchet
November 19, 2008 at 8:32 pmThanks so much!
I had never heard of this and I am not that good with computers, so now I have a very obvious question: will this process cause any loss of files or anything like that?
This is not like formatting the drive, right?
You didn’t mention anything, so it probably doesn’t. But I just need to double check.Thanks a lot!
Jorge
Terry Esslinger
November 19, 2008 at 9:53 pmNo, it is not reformatting. When I did it I did not lose a thing. BUT your mileage may vary.
Jorge Trinchet
November 19, 2008 at 10:47 pmThanks a lot for such a quick reply! All right, sounds good. We will go for it.
Jorge
Jorge Trinchet
November 19, 2008 at 10:50 pmSorry for posting so much.
I just check the drive and it says that it is actually NTFS. So I guess that I don’t need to convert it. I’m relieved!
Do you have any other ideas on why Vegas rendered the sequence as two separate files?
Thanks! -
Jorge Trinchet
November 20, 2008 at 5:43 pmTerry, you were right!
The C: in my computer is formatted as NTSF, but when I saved that file, I saved it to a portable drive that I have, which is formatted as FAT32. So that is probably why it did it. Thanks so much!!!Jorge
Jorge Trinchet
November 22, 2008 at 5:27 pmTerry,
I’ve been trying to convert my portable drive to NTFS, but I have not been able to.
It is asking me: Enter current volume label for drive G: (like I said, I am converting a portable drive).
In the directions that you gave me you said: It will ask for that name in confirmation.
But what name?
I have typed: NTFS
G: /FS:NTFS
G:No matter what I type, it always says: An incorrect volume label was entered for this drive.
What is it asking for?
Thanks!Jorge
Jorge Trinchet
November 22, 2008 at 10:09 pmI have tried all kinds of name combinations, and it keeps saying the same: An incorrect volume label was entered for this drive.
This is how it goes:When I type VOL G:
It says: Volume in drive G is My Book
Volume Serial Number is B1D0-196EThen I type: CONVERT G: /FS:NTFS
It says: The type of the file system is FAT32.
Enter current volume label for drive G:I type: My Book B1D0-196E
It says: An incorrect volume label was entered for this drive.
By the way, sometimes when I type this directly: CONVERT G: /FS:NTSF (without previously typing VOL G:), it says: Conversion from FAT32 to NTSF volume is not available.
Any ideas?
Thanks,Jorge
